atpalmer Posted April 19, 2009 Report Share Posted April 19, 2009 I am building a solar cell test system like a student project. I have access to labview 8.5 and i wan't to run the solar toolkit vi at the link below. The toolkit is written for version 8.6 and won't open. Is there any way I can get an 8.5 compatible version? If someone with 8.6 can be so kind as to do a save as and post the result it would benefit everyone. Thank you if this is possible. The attachment below can also be found at the link above. Quote Link to comment
2and4 Posted April 19, 2009 Report Share Posted April 19, 2009 QUOTE (atpalmer @ Apr 17 2009, 11:20 PM) I am building a solar cell test system like a student project. I have access to labview 8.5 and i wan't to run the solar toolkit vi at the link below. The toolkit is written for version 8.6 and won't open. Is there any way I can get an 8.5 compatible version? If someone with 8.6 can be so kind as to do a save as and post the result it would benefit everyone.http://zone.ni.com/devzone/cda/epd/p/id/5918 Thank you if this is possible. The attachment below can also be found at the link above. I opened the code in LabVIEW 8.6 and "Saved for Previous Version (8.5)". I got some warnings when I did that so I don't know if it worked. Unfortunately I don't have LabVIEW 8.5 on my laptop so I couldn't check it. Anyway, here's a zip file of what was generated. Hope it works... Quote Link to comment
atpalmer Posted April 21, 2009 Author Report Share Posted April 21, 2009 QUOTE (2and4 @ Apr 18 2009, 03:19 PM) Anyway, here's a zip file of what was generated. Hope it works... That worked. Thank you very much Quote Link to comment
Nikita Posted April 22, 2009 Report Share Posted April 22, 2009 QUOTE (atpalmer @ Apr 18 2009, 09:50 AM) I am building a solar cell test system like a student project. I have access to labview 8.5 and i wan't to run the solar toolkit vi at the link below. The toolkit is written for version 8.6 and won't open. Is there any way I can get an 8.5 compatible version? If someone with 8.6 can be so kind as to do a save as and post the result it would benefit everyone.http://zone.ni.com/devzone/cda/epd/p/id/5918 Thank you if this is possible. The attachment below can also be found at the link above. Hello atpalmer , Can you please give me some information on what project you are working on ? Thanks, Nikita Quote Link to comment
atpalmer Posted April 22, 2009 Author Report Share Posted April 22, 2009 QUOTE (Nikita @ Apr 20 2009, 09:00 PM) Hello atpalmer ,Can you please give me some information on what project you are working on ? Thanks, Nikita I have a supply of surplus solar cells and I will build a few small panels. It is important that the cells are matched otherwise one bad cell will bring down the performance of the entire panel. To test the cells I've built a box with a 300W halogen work light and fan with a mount for the individual solar cells. Since I have so many cells to test I decided to try and automate the testing with labview and a budget daq system. My goal is to the build the eniter system for under $50. Part of the reasoning behind the project is to advance my understanding of solar cell testing and performance. I do not really need an elaborate test system to simply build a good panel. Quote Link to comment
Nikita Posted April 24, 2009 Report Share Posted April 24, 2009 QUOTE (atpalmer @ Apr 21 2009, 10:56 PM) I have a supply of surplus solar cells and I will build a few small panels. It is important that the cells are matched otherwise one bad cell will bring down the performance of the entire panel. To test the cells I've built a box with a 300W halogen work light and fan with a mount for the individual solar cells. Since I have so many cells to test I decided to try and automate the testing with labview and a budget daq system. My goal is to the build the enitre system for under $50.Part of the reasoning behind the project is to advance my understanding of solar cell testing and performance. I do not really need an elaborate test system to simply build a good panel. Thanks atpalmer !!!! Quote Link to comment
