Pulse width modulation (signal interpretation)
WAtoMA
Hello all,
I am a grad student in chemistry. I am in the beginning stages of understanding/utilizing Labview 6.0.
My objective is to try and update a very old Raman Spectrometer from a stepper motor driven chart recorder to a digital interface using Labview.
What I know of the signal that is received from the instrument is:
There are two signals.
One is a constant steady state signal giving me a constant pulse from a point of reference (which needs to be user defined). This will define my x-axis in wavenumbers.
The other signal is a variation signal received from a Photomultiplier tube. This signal is a voltage difference which correlates to a given intensity on my y-axis.
The VI's which I have been investigating for this purpose are of the Pulse train category.
Can anyone tell me if I am on the right track? Will the typical Generate Pulse Train.vi from the counter palette serve the needs of my project. I'm assuming I need to use
an analog input vi. Would AI Aquire Waveforms.vi be the one I need....since I am acquiring multiple signals?
Does anyone have any tips or has anyone encountered a similar project?
