XML Using MS XML DOM
I am using MS XML DOM ActiveX to parse through XML file I have. I want to retrieve comments from the XML document and I tried using "comment()" function along with the xPath String.
It seems to be not working. Actually when I try to retrieve all the elements from an XML document, it does not get the comments at all. Any way out of this.
Thanks...
As candius pointed out, you're looking for nodes, not elements. Sticking with DOM methods, if you iterate over each node and compare its nodeType, you're looking for ones of the NODE_COMMENT (8) variety.
If you want more than hints, show us what you have so we have a starting point.
