Brian G Posted April 25, 2009 Report Posted April 25, 2009 Hi, I'm trying to collection some readings from strain gages with the attached .VI. I built the VI with the measurement and automation studio. If you look at the screenshots, I'm able to aquire nice, clean signals but if you check out the text file that gets written, it's just a bunch of noise. Does anyone have any ideas how I can fix this? Thanks, Brian Quote
LAVA 1.0 Content Posted April 26, 2009 Report Posted April 26, 2009 I would try to set the 'Append to file' to true. What is the value that you measured on the graph? Currently the value is 25 m. One advice, I wouldn't use a spreadsheet string format, especially because you loose precision and the decimal sign might change. Ton Quote
