How to disable right mouse click
Hello
I've searched topics related to mine but couldn't find any, so my question is:
I need to DISABLE the option that appear after right click in any place of the running application called "Remote Panel Server". I've already unmarked the "run-time menu option" on Window appearence and worked with others menu itens, but now only this option remain active and I don't know how to turn it off.
Thanks
Edited by AndreLuis
Looks like LabVIEW Web Server is enabled on your machine. Open LabVIEW go to Tools>>Options menu. You will find WebServer:Configuration in the Listbox on the left. Click this option to find a Checkbox for Enable Web Server. Remove the check mark and save. Now the right click option should be gone. The WebServer Configuration panel may be in a slightly different place based on the version of LabVIEW you have. The above mentioned location is with respect to LabVIEW 8.6.1
It worked
thanks thomas
