Mark Balla Posted November 29, 2008 Report Posted November 29, 2008 Name: FP SubVI Fixer ver 6 LV 2009 Submitter: Mark Balla Submitted: 10 Mar 2010 File Updated: 10 May 2010 Category: LabVIEW IDE Version: 6.0.0 LabVIEW Version: 2009 License Type: BSD (Most common) Author: Mark Balla LAVA Name: mballa Contact Info: Contact via PM on lavag.org LabVIEW Versions: LabVIEW 8.2, 8.5, 8.6, 2009 Dependencies: None Description: The FP SubVI Fixer is a set of VI Server and Scripting function that will automatically wire the FP controls and indicators to the connector pane and will arrange the FP items based on a configuration setting. Past Deveopment of this tool can be found here Installation and instructions: Place the three items (FP FIX SUBVI, _FIXER Subvis Main, _Subvis for FIXER) in the \National Instruments\Labview 8.x\project folder In the LabVIEW development environment open a vi that needs it front panel fixed. select tools then the FP FIX SUBVI item. the fixer will popup breifly and then be minimized. Select the vi to be fixed. Press Ctrl-Shift-Space to bring up the FP Sub VI Fixer. Click on the various buttons to fixe the subvis front panel. Examples: Please view the following screencast videos to see how it works. Acknowledgements: Thanks to Aristos Queue and PJM_labview for helping me take this to the next level. Version History: v6.0.0: Initial release of the code. 1 Using the by arrangement function http://www.screencas...cc-235e8cca0cd1 2 Using Settings http://www.screencas...3b-37fe090f1eb0 3 Using the by Pairs function http://www.screencas...34-47266a6860a3 Click here to download this file 1 Quote
Popular Post Mark Balla Posted March 10, 2010 Author Popular Post Report Posted March 10, 2010 1: Using the By Arrangement function http://www.screencast.com/t/jrvrm5l1eu2: Using Settings http://www.screencast.com/t/hU5E0eEI 3:Using Wire by Pairs functionhttp://www.screencast.com/t/4eUSYTMfc97 3 Quote
Ton Plomp Posted March 26, 2010 Report Posted March 26, 2010 Nice Tool, just one very annoying issue. This VI has the bad habit to steal focus (I have not looked for a solution), but because I really like ctrl-w I close this tool more than I like. Could you set the VI to be non-closeable and register for the Application Close? event and add a 'close' button? Ton Quote
Ton Plomp Posted May 11, 2010 Report Posted May 11, 2010 Mark have you tried to run this tool with the JKI RCF framework active? I have a feeling that the 'VI Activation event' is not triggered in your app. Ton Quote
Mark Balla Posted August 19, 2012 Author Report Posted August 19, 2012 The code to integrate the fixer with quick drop can be found Here Quote
