MartinMcD Posted July 7, 2010 Report Share Posted July 7, 2010 Hello there, I have a weird problem with a very simple exe that I've built. As you can see in the attached image, when I launch the application (which happens correctly) two icons show up on the task bar. Does anyone know whey this happens please? Thank you, Martin Quote Link to comment
jgcode Posted July 7, 2010 Report Share Posted July 7, 2010 Hello there, I have a weird problem with a very simple exe that I've built. As you can see in the attached image, when I launch the application (which happens correctly) two icons show up on the task bar. Does anyone know whey this happens please? Thank you, Martin Hi Martin (There is no image attached) I have seen this before but not with LV2009 - what version of LV are you using? Place the following in the .exe's ini file: HideRootWindow=True This fixed it for me (LV 8.5.1 I think) Cheers -JG Quote Link to comment
MartinMcD Posted July 7, 2010 Author Report Share Posted July 7, 2010 Hi Martin (There is no image attached) I have seen this before but not with LV2009 - what version of LV are you using? Place the following in the .exe's ini file: HideRootWindow=True This fixed it for me (LV 8.5.1 I think) Cheers -JG Great, thank you I will try that and see how I get on - thank you for the help. I do have LV2009. It seems intermittent as it did it this morning and then not this afternoon although I didn't do a rebuild. Cheers, Martin Quote Link to comment
crelf Posted July 14, 2010 Report Share Posted July 14, 2010 Place the following in the .exe's ini file: HideRootWindow=True Indeed - and you can find more information on this and many more ini key settings here: http://labviewwiki.org/LabVIEW_configuration_file Quote Link to comment
