amila Posted May 9, 2009 Report Share Posted May 9, 2009 Hi all, I attach here my vi. Basically, what it does are: 1. read an image (in this case, an image of a strip) 2. use IMAQ rake to scan the image (from left to right direction) and detect all edges 3. calculate the midpoint of the strip if found 2 edges: there is only 1 midpoint if found 4 edges: there are 2 midpoint 4. put into array and display the minimum and maximum x-value in the array The problem I've got are: 1. The minimum x-value is wrong because it display 0 - this is because when I merge the 2 arrays (outside loop), there will be 0 value to be placed in the array 2. how should I insert elements from array A2 just after inserting elements from array A1. For example: In the case if 4 edges are detected, let say the points are (i) 55,100 (ii) 60,100 (iii) 150,100 (iv) 155,100 the midpoints are (example) 57.5,100 and 152.5,100 in the A3, how should I place these two midpoints one after another? Hope all of you can give me a hand on this. I'm using Labview 8.5.1 Many thanks. Amila Quote Link to comment
Neville D Posted May 9, 2009 Report Share Posted May 9, 2009 QUOTE (amila @ May 8 2009, 05:52 AM) if found 2 edges: there is only 1 midpoint if found 4 edges: there are 2 midpoint The problem I've got are: 1. The minimum x-value is wrong because it display 0 - this is because when I merge the 2 arrays (outside loop), there will be 0 value to be placed in the array 2. how should I insert elements from array A2 just after inserting elements from array A1. For example: In the case if 4 edges are detected, let say the points are (i) 55,100 (ii) 60,100 (iii) 150,100 (iv) 155,100 the midpoints are (example) 57.5,100 and 152.5,100 in the A3, how should I place these two midpoints one after another? Well, just check first if you have 2 or 4 edges. Use a case structure to selectively build the arrays based on each case (with the build arrays inside). Or Make a cluster for each edge: {Pt1[x,y], Pt2[x,y], Mid-pt[x,y]} and output the cluster at every iteration where an edge is found. Then you have an array of clusters with the solutions inside. N. Quote Link to comment
LAVA 1.0 Content Posted May 9, 2009 Report Share Posted May 9, 2009 If you need the center of a rectangular area (like you seem to need) you have allready such a VI inside your VI.lib. If you install OpenG's nilib rectangle you will have a rectangle palette added. One of the VIs is RectCentroid. This returns the center point of a rectangle. Ton Quote Link to comment
amila Posted May 9, 2009 Author Report Share Posted May 9, 2009 QUOTE (Neville D @ May 8 2009, 07:42 PM) Well, just check first if you have 2 or 4 edges. Use a case structure to selectively build the arrays based on each case (with the build arrays inside).Or Make a cluster for each edge: {Pt1[x,y], Pt2[x,y], Mid-pt[x,y]} and output the cluster at every iteration where an edge is found. Then you have an array of clusters with the solutions inside. N. Hi Neville, Thanks for your reply. I want to know 1. for case of 4 edges, should I build 2 arrays in the case structure or only 1 array? 2. how would I merge the array from both cases without having any 0,0 value in the merged array? Thanks. Quote Link to comment
Neville D Posted May 9, 2009 Report Share Posted May 9, 2009 QUOTE (amila @ May 8 2009, 02:08 PM) 1. for case of 4 edges, should I build 2 arrays in the case structure or only 1 array?2. how would I merge the array from both cases without having any 0,0 value in the merged array? Build the arrays any way you want. Run through the arrays with a FOR loop and discard any pts that you don't want. Quote Link to comment
amila Posted May 9, 2009 Author Report Share Posted May 9, 2009 QUOTE (Neville D @ May 8 2009, 10:15 PM) Build the arrays any way you want. Run through the arrays with a FOR loop and discard any pts that you don't want. I tried to build 2 arrays in case of 4 edges and the combined both of them to form 1 array. But when I looked to the save file, the array of these midpoints have 4 columns. And for the case of 2 edges, value '0' will be placed in the array. How can I turn it into 2 column for x and y only? Quote Link to comment
LAVA 1.0 Content Posted May 10, 2009 Report Share Posted May 10, 2009 QUOTE (amila @ May 8 2009, 11:08 PM) Hi Ton,Unfortunately I cannot install OpenG's because I'm using university's computer and we couldn't install anything without authorization. And actually I need a center point of every pair of edges of this strip. Just for clearity these VIs are allready present inside your vi.lib, have a look at: vi.lib\picture\picturesupport.llb Ton Quote Link to comment
amila Posted May 13, 2009 Author Report Share Posted May 13, 2009 QUOTE (Neville D @ May 8 2009, 07:42 PM) Well, just check first if you have 2 or 4 edges. Use a case structure to selectively build the arrays based on each case (with the build arrays inside).Or Make a cluster for each edge: {Pt1[x,y], Pt2[x,y], Mid-pt[x,y]} and output the cluster at every iteration where an edge is found. Then you have an array of clusters with the solutions inside. N. Hi Neville, I've tried the second suggestion: make a cluster for each edge. I have the results that I want. But the problem is how to save all of them in a file? Many thanks. Amila Quote Link to comment
Neville D Posted May 13, 2009 Report Share Posted May 13, 2009 QUOTE (amila @ May 12 2009, 05:58 AM) I've tried the second suggestion: make a cluster for each edge. I have the results that I want. But the problem is how to save all of them in a file? You can't use the Express VI's to do anything but very simple tasks. Look at examples of writing data to file. You already have the strings, write a simple VI to put that stuff into a file. You can also right-click and convert an ExpressVI to a regular VI to look at the code inside to see if you can modify/re-use any of it. But from the level of questions you are asking, that might just further confuse you. I would look at the file write examples and go from there. Maybe you can write data line by line (within the loop) instead of collecting it outside the loop and writing everything at once. But the file header (column names) would have to be written prior to loop start. N. Quote Link to comment
