Finding Shared Variables Function
It is also possible to do a text search for the name of the shared variable to find a specific shared variable. LabVIEW will return matches for the hidden shared variable labels. Actually, the SV label includes the path so including a backslash ('\') before the shared variable name helps to eliminate other unwanted matches. This is not the ideal solution but it works well in many cases.
