Case syntax in Teststand
Clio75
Hello
I'm have bumped into a challenge, and I like your opinion/help/suggestions.
The Select case in Teststand 4.1.1 is not behaving like I was hoping for.
Several products in the test. And from a bar code reader it will select witch sequence to run
More that one product is using the same sequence But they have different number from the barcode reader.
So I put products that can have the same test into the same case. But that the case was not been selected when I runed any of products. If I but them in separate cases it works.
It's not a big problem, but it is a pain in the ###### thing. The hole sequense is growing faster and faster. And at the end it will be at lest twich the size I was hoping for.
This is working.
Selsect
Case 1
case 2
case 3
case 4
End select
Thins is not.
Select
case 1,2
case 3,4
end Select
Please help me if you have some advice
