scls19fr Posted May 13, 2009 Report Share Posted May 13, 2009 Hello, I'm using an express VI to fill a table. In my example I have 2 float values in a signal. I set the express VI to add timestamp in the table... but the default behaviour of this VI is quite surprising. Timestamp appear in the first two columns (instead of being only on the first column) Is there an easy way to modify this default behaviour ? If my signal is composed of 10 values... the timestamp appear 10 times... but it's the same !!! I don't understand why they (NI) do it like that ! I think that one solution could be to convert this express VI in a classic VI. Kind regards Quote Link to comment
santi122 Posted May 14, 2009 Report Share Posted May 14, 2009 Hi scls, try this.. Quote Link to comment
paramesium Posted June 12, 2009 Report Share Posted June 12, 2009 maybe u will like this =) the item i have added is delete from array. Best, paramesium Quote Link to comment
