crelf Posted May 16, 2009 Report Share Posted May 16, 2009 I got a few minutes downtime, so I figure now is as a good time as any to look as SCC integration in LabVIEW. We use SVN (we use the needs-lock model, so we checkout/checkin everything - and no, I'm not looking to debate that model ), so I'm looking at PushOK (at $27 a license, who can argue?) - so far so good. Anything I should look out for using PushOK? Quote Link to comment
LAVA 1.0 Content Posted May 16, 2009 Report Share Posted May 16, 2009 The only thing limited on the pushOK interface is that you always get a 'Action Succeeded Dialog' that you have to 'OK'. Besides PushOK there are other gateways, TamTam for $10 or another one for €70 whose name I can't remember, haven't tested them, I was pleased with PushOK enough. Remember you will need a full-blown client (like Tortoise) for tagging and branching. Ton Quote Link to comment
crelf Posted May 16, 2009 Author Report Share Posted May 16, 2009 QUOTE (Ton @ May 15 2009, 02:09 PM) The only thing limited on the pushOK interface is that you always get a 'Action Succeeded Dialog' that you have to 'OK'. You might want to download the latest version - mine doesn't do that. Quote Link to comment
TobyD Posted May 19, 2009 Report Share Posted May 19, 2009 We have considered trying the PushOK plug-in. Currently we use TortoiseSVN or SilkSVN and do all SVN transaction outside of LabVIEW. For anyone who has used it, do you think the integration provided by the PushOK plug-in is good enough to make it worthwhile? Quote Link to comment
