Help with loop image save
Hello everyone,
I'm new here and in to labview.
I need to create a movie from an intensity graph, but I will do this saving images from the graph 24 frames per second, in a loop way.
I try using a "WRITE JPEG FILE.vi" but the problem is that when I stipulate a path it overwrite the file in each loop, otherwise with no default path, when running it keep me asking what name to save.
I need to make an automatic way to save each time (frame) with a different name, is that a way?
thanks, sorry for my english :)
Check out the String palette. You can build a string from a base name for your file to which you'll concatenate the loop number (Format Into String). Then build the filepath using the "Build Path" VI in the file palette. Check the help (Ctrl-H) to see how you should wire the Format Into String primitive.
post-10515-1243998586.png?width=400
