TCP Connection not working after application build
Hey guys,
I have created a VI that controls a motor control device using Telnet (TCP Open, TCP Write, TCP Read, and TCP Close). The program works fine in Labview, but when I build an executable it doesn't communicate. I tried building an installer and putting the exe on another machine and the same thing happens. These machines are not running firewalls and they are on a closed network. I originally created the VI's in Labview 8.6.1 full, but it didn't have the application builder. I saved the VI for use with 8.5 and built the application from LabVIEW 8.5 Developer installed on a different PC. Any ideas as to why the TCP functions aren't working?
Thanks in advance for the help.
You will need to keep the VI that opened the telnet session running (not just kept in memory). I had the same issue and found some threads here and on NI about it. To tired to explain why. Give me coffee.
Try it.
