Programmatic app builds in LV 7
  • 1 year later...
Sorry for resurecting an old thread but can't you just use SystemExec to make sure LabVIEW is running? Or is the problem is to locate the LabVIEW directory?
  • 1 month later...
  Jim Kring said:
LabVIEW 7's app builder has added a VI for programatically building apps.  I have created this command line tool.  However, it requires that LabVIEW development environment is running  :cry:
Usage:
build.exe -- RelOrAbsPathToScript
-Jim
53[/snapback]
hi
I am using Lab veiw.I have downloaded the Run Time Engnie for Labveiw 7.0 .I have installed it as well but I am not able to see the Application build in the Lab View.
I fell it has not been installed properly.I am using evaluation version of Lab Veiw.
Please help me to get the right Run Time Engin and the procedure to install the same.
Regards
Padma
  Padma said:
hi
1171[/snapback]
Padma,
You require the application builder for LabView to compile code. What you have is the run time engine - this is what you install on machines that are to run your compiled code.
Cheers,
James
Regards
Padma
1171[/snapback]
You can't build applications or run the Application builder in the Evaluation Version of LabVIEW... Sorry. :(
