Jim Kring Posted May 24, 2003 Report Share Posted May 24, 2003 LabVIEW 7's app builder has added a VI for programatically building apps. I have created this command line tool. However, it requires that LabVIEW development environment is running :cry: Usage: build.exe -- RelOrAbsPathToScript -Jim Download File:post-15-1073109764.zip Quote Link to comment
jpdrolet Posted June 9, 2004 Report Share Posted June 9, 2004 Sorry for resurecting an old thread but can't you just use SystemExec to make sure LabVIEW is running? Or is the problem is to locate the LabVIEW directory? Quote Link to comment
Jim Kring Posted June 9, 2004 Author Report Share Posted June 9, 2004 I have created a much more full-featured version that fixes this limitation: LVBLD - Command Line Build Tool Quote Link to comment
Padma Posted July 19, 2004 Report Share Posted July 19, 2004 LabVIEW 7's app builder has added a VI for programatically building apps. I have created this command line tool. However, it requires that LabVIEW development environment is running :cry: Usage: build.exe -- RelOrAbsPathToScript -Jim 53[/snapback] hi I am using Lab veiw.I have downloaded the Run Time Engnie for Labveiw 7.0 .I have installed it as well but I am not able to see the Application build in the Lab View. I fell it has not been installed properly.I am using evaluation version of Lab Veiw. Please help me to get the right Run Time Engin and the procedure to install the same. Regards Padma Quote Link to comment
James McAnanama Posted July 19, 2004 Report Share Posted July 19, 2004 hi I am using Lab veiw.I have downloaded the Run Time Engnie for Labveiw 7.0 .I have installed it as well but I am not able to see the Application build in the Lab View. 1171[/snapback] Padma, You require the application builder for LabView to compile code. What you have is the run time engine - this is what you install on machines that are to run your compiled code. Cheers, James Quote Link to comment
Michael Aivaliotis Posted July 19, 2004 Report Share Posted July 19, 2004 ....I fell it has not been installed properly.I am using evaluation version of Lab Veiw. Please help me to get the right Run Time Engin and the procedure to install the same. Regards Padma 1171[/snapback] You can't build applications or run the Application builder in the Evaluation Version of LabVIEW... Sorry. Quote Link to comment
