Gary Rubin Posted July 21, 2009 Report Posted July 21, 2009 Why can't I do this? Both data type are 32-bit, so is there any reason why I shouldn't be able to do that conversion inplace? Quote
crelf Posted July 21, 2009 Report Posted July 21, 2009 Both data type are 32-bit, so is there any reason why I shouldn't be able to do that conversion inplace? Both types aren't 32-bit, at least not yet... Quote
Gary Rubin Posted July 21, 2009 Author Report Posted July 21, 2009 (edited) Both types aren't 32-bit, at least not yet... Are you going to explain that comment, or just leave it hanging out there for a while? Edited July 21, 2009 by Gary Rubin Quote
crelf Posted July 21, 2009 Report Posted July 21, 2009 Are you going to explain that comment... Ohhhh - I get what you mean. Um, in that case, they are indeed both 32 bit, but they're not the same datatype. I agree that it would be nice to see some implaceness here, but it's certainly not something I would have expected. More importantly, why would you want to do that? Can't you just use the I32 convesion outside of the structure and get implaceness, or are you trying to demonstrate the root issue that would normally be applied to something bigger? Quote
Gary Rubin Posted July 21, 2009 Author Report Posted July 21, 2009 Sorry for the brusqueness. I thought you knew something about LabVIEW's internal memory and were being cute... I was trying this inplace trick because when I tried doing the conversion normally, it was not done inplace. I was hoping that the inplace structure would get rid of a buffer allocation on the output of a Single->U32 conversion Quote
crelf Posted July 21, 2009 Report Posted July 21, 2009 Sorry for the brusqueness. I thought you knew something about LabVIEW's internal memory and were being cute... No worries - I don't need to know anything about LabVIEW's internal memory to be cute I was trying this inplace trick because when I tried doing the conversion normally, it was not done inplace. I can understand why the inplace structure doesn't have it yet, but I'd expect the normal manual conversion to have it Quote
Gary Rubin Posted July 21, 2009 Author Report Posted July 21, 2009 I can understand why the inplace structure doesn't have it yet, but I'd expect the normal manual conversion to have it Here's what I'm seeing. I'm surprised there's no allocation dot on the output of the decimate. Quote
crelf Posted July 21, 2009 Report Posted July 21, 2009 I'm surprised there's no allocation dot on the output of the decimate. OK - now I'm really confused - why would there be a allocation dot on the output of the decimate? The output is still a 1D array of SGLs - it's just got fewer elements. Quote
Gary Rubin Posted July 21, 2009 Author Report Posted July 21, 2009 OK - now I'm really confused - why would there be a allocation dot on the output of the decimate? The output is still a 1D array of SGLs - it's just got fewer elements. I didn't realize that it would be able to reuse the same space for the new array, especially given the fact that one is a decimation of the other (i.e. the output elements are not contiguous in input array). Quote
PaulG. Posted July 21, 2009 Report Posted July 21, 2009 I didn't realize that it would be able to reuse the same space for the new array, especially given the fact that one is a decimation of the other (i.e. the output elements are not contiguous in input array). I'm scratching my head as well. Are you possibly confusing array copies with coercion? Quote
Gary Rubin Posted July 21, 2009 Author Report Posted July 21, 2009 I'm scratching my head as well. Are you possibly confusing array copies with coercion? Nope, my coercion dots are red. Quote
Daklu Posted July 21, 2009 Report Posted July 21, 2009 Why can't I do this? Both data type are 32-bit, so is there any reason why I shouldn't be able to do that conversion inplace? Pure speculation here... My guess is that in memory, the computer not only needs to know the value of the 32 bits, but it needs to know the type of data it is as well. It's been eons since I've done any C/C++ programming, but I believe changing the data type in place would mess up the pointers. They would think they are still pointing to a sgl but are in fact pointing to an int. ('New math' takes on a whole new meaning!) Therefore, type casting will always create a new buffer with a new pointer (and new pointer type) pointing to it. Quote
crelf Posted July 21, 2009 Report Posted July 21, 2009 I didn't realize that it would be able to reuse the same space for the new array, especially given the fact that one is a decimation of the other (i.e. the output elements are not contiguous in input array). Right - the contigious part doesn't have anything to do with whether it can be inplace or not - it's about the space (and the datatype of that space(s)), not the values. Quote
PaulG. Posted July 21, 2009 Report Posted July 21, 2009 Nope, my coercion dots are red. My apologies. I should never have stopped here. This is getting so confusing I was the one confusing coercion with allocation. "Never mind" Quote
Gary Rubin Posted July 22, 2009 Author Report Posted July 22, 2009 This is getting so confusing I was the one confusing coercion with allocation. Maybe the subtitle of this topic should have been "down the rabbit hole". Then again, most of my topics seem to end up that way Quote
crelf Posted July 22, 2009 Report Posted July 22, 2009 Maybe the subtitle of this topic should have been "down the rabbit hole". It's a wonderful wonderful place to be As an aside, anyone hear about the new "Alice in Wonderland" movie coming out? Depp and Burton - here we go again... Quote
dannyt Posted July 22, 2009 Report Posted July 22, 2009 It's a wonderful wonderful place to be As an aside, anyone hear about the new "Alice in Wonderland" movie coming out? Depp and Burton - here we go again... Well just to stay of topic, a lot of that was filmed last year down in Cornwall and Devon, a friend of mine who is a school teacher took one months unpaid time of to be an extra in the film. She said it was a very interesting but bizarre experience. Quote
jzoller Posted July 22, 2009 Report Posted July 22, 2009 It looks like the decimate never shows an allocation. Given that the decimated arrays each has an extra 4 bytes (for dimSize) padded onto the front, they couldn't all be re-using the same memory... The sum of the parts would be greater than the whole. Quote
crelf Posted July 22, 2009 Report Posted July 22, 2009 Given that the decimated arrays each has an extra 4 bytes (for dimSize) padded onto the front, they couldn't all be re-using the same memory... An array is an array - don't they all have dimSize at the front? Quote
Gary Rubin Posted July 22, 2009 Author Report Posted July 22, 2009 An array is an array - don't they all have dimSize at the front? Right, so I think that what he's saying is that when the decimation turns an N-element array into 4 N/4-element arrays, there should be 3 extra dimSizes as compared to the original array. That should mean that more memory is needed. Quote
crelf Posted July 22, 2009 Report Posted July 22, 2009 Right, so I think that what he's saying is that when the decimation turns an N-element array into 4 N/4-element arrays, there should be 3 extra dimSizes as compared to the original array. That should mean that more memory is needed. That might be the case if you wire out two or more of the decimated arrays, but not in the BD above where only one of them is wired out. Quote
Daklu Posted July 22, 2009 Report Posted July 22, 2009 She said it was a very interesting but bizarre experience. Just watching a Tim Burton movie is an interesting but bizarre experience... I can't image being in one. Quote
jzoller Posted July 22, 2009 Report Posted July 22, 2009 That might be the case if you wire out two or more of the decimated arrays, but not in the BD above where only one of them is wired out. There's no allocation shown even with all outputs wired. Quote
PaulG. Posted July 22, 2009 Report Posted July 22, 2009 Well just to stay of topic, a lot of that was filmed last year down in Cornwall and Devon, a friend of mine who is a school teacher took one months unpaid time of to be an extra in the film. She said it was a very interesting but bizarre experience. Dude! You have a friend who was an extra in a Burton film?! Tim Burton is brilliant. One of my all-time favorites. I remember watching Mars Attacks! with my 10 and 12 year old (at the time) nephews. Talk about a party. PaulG now returns this hijacked thread to it's proper subject. Quote
crelf Posted July 23, 2009 Report Posted July 23, 2009 There's no allocation shown even with all outputs wired. Interesting... Quote
