Koli Posted July 22, 2009 Report Posted July 22, 2009 Hi! Anybody has done DTW in LabView somehow? Quote
tschrama Posted August 13, 2009 Report Posted August 13, 2009 (edited) Hi, I know of one scientific journal publication (I think brazilian autheurs..) mentioning a DTW programmed in LabVIEW. I can look it up for you if you want it. I never found any conde on the net so I programmed the DTW-algorithm myself in labVIEW. I might be able to share it. Where do you need it for? Kindest regards, Thijs Schrama Edited August 13, 2009 by tschrama 1 Quote
Anders Björk Posted August 13, 2009 Report Posted August 13, 2009 On 8/13/2009 at 12:12 PM, tschrama said: Hi, I know of one scientific journal publication (I think brazilian autheurs..) mentioning a DTW programmed in LabVIEW. I can look it up for you if you want it. I never found any conde on the net so I programmed the DTW-algorithm myself in labVIEW. I might be able to share it. Where do you need it for? Kindest regards, Thijs Schrama I am also looking for DTW in labview, does you code have section that can shrink and expand? Quote
Koli Posted August 18, 2009 Author Report Posted August 18, 2009 On 8/13/2009 at 12:12 PM, tschrama said: Hi, I know of one scientific journal publication (I think brazilian autheurs..) mentioning a DTW programmed in LabVIEW. I can look it up for you if you want it. I never found any conde on the net so I programmed the DTW-algorithm myself in labVIEW. I might be able to share it. Where do you need it for? Kindest regards, Thijs Schrama Hi! I wan't to use it to calculate the time-delay between my two microphon-signal, to localize the sound-source... Can you share it then? Thanks:Koli Quote
tschrama Posted September 1, 2009 Report Posted September 1, 2009 On 8/18/2009 at 7:30 AM, Koli said: Hi! I wan't to use it to calculate the time-delay between my two microphon-signal, to localize the sound-source... Can you share it then? Thanks:Koli "does you code have section that can shrink and expand?" LOL, no the code does not shrink or expand.. the code is stable.. but what is does: yes, it find the optimum alignment between two vectors of possible dissimilar length.. it real DTWarping published by Eamonn Keogh. let me find the code first .. and mail me at tschrama@fsw.leidenuniv.nl Best regards, Thijs Schrama Quote
