Phil Duncan Posted July 25, 2009 Report Posted July 25, 2009 Name: Multistate Boolean LED Indicator Submitter: Phil Duncan Submitted: 04 Jul 2009 Category: X-Controls LabVIEW Version: 8.5 Version: 1.0.0 License Type: BSD (Most common) Make this available on the VI Package Network?: Undecided Multistate Boolean LED Indicator V1.0.0 Copyright © 2008, Phillip Duncan All rights reserved. Author: Phillip Duncan --see readme file for contact information Background: I have had many people ask for an LED type indicator for their project. During development, I often get asked to have this Boolean (ie 2 state) indicator display one of (more than 2) colours. Whilst that in itself is not difficult, more often than not I am then asked to make the Boolean LED flash as well to highlight certain states. For example a single LED will often need to indicate the following states: OFF (green, red or grey) ON (Green, red or grey) Flashing (green, red, any other colour) I have had so much demand for this functionality, that I decided to develop this XControl and share it with the LabVIEW Community. Many thanks must go to Aristos Queue and his inspiring "Scrolling LED XControl" example. Description: This XControl is a typical Boolean LED indicator that can also be configured to flash between two user defined colours. The flashing interval can also be modified. When not flashing, the XControl behaves as a normal Boolean LED. This XControl is an indicator only is is not intended to be used as a control. Dependancies: There are no OpenG dependencies for this XCtonrol Known Issues: If you save this code for version 8.0/8.2, you may encounter issues trying to assign multiple properties in one property node. This is a bug in LabVIEW 8.0/8.2 Change Log: 1.0.0 Initial release Click here to download this file 1 Quote
ndingle Posted August 8, 2009 Report Posted August 8, 2009 Thank you. This is just what I need for a current project. Quote
Robby Posted September 15, 2009 Report Posted September 15, 2009 Name: Multistate Boolean LED Indicator Submitter: Phil Duncan Submitted: 04 Jul 2009 Category: X-Controls LabVIEW Version: 8.5 Version: 1.0.0 License Type: BSD (Most common) Make this available on the VI Package Network?: Undecided Multistate Boolean LED Indicator V1.0.0 Copyright © 2008, Phillip Duncan All rights reserved. Author: Phillip Duncan --see readme file for contact information Background: I have had many people ask for an LED type indicator for their project. During development, I often get asked to have this Boolean (ie 2 state) indicator display one of (more than 2) colours. Whilst that in itself is not difficult, more often than not I am then asked to make the Boolean LED flash as well to highlight certain states. For example a single LED will often need to indicate the following states: OFF (green, red or grey) ON (Green, red or grey) Flashing (green, red, any other colour) I have had so much demand for this functionality, that I decided to develop this XControl and share it with the LabVIEW Community. Many thanks must go to Aristos Queue and his inspiring "Scrolling LED XControl" example. Description: This XControl is a typical Boolean LED indicator that can also be configured to flash between two user defined colours. The flashing interval can also be modified. When not flashing, the XControl behaves as a normal Boolean LED. This XControl is an indicator only is is not intended to be used as a control. Dependancies: There are no OpenG dependencies for this XCtonrol Known Issues: If you save this code for version 8.0/8.2, you may encounter issues trying to assign multiple properties in one property node. This is a bug in LabVIEW 8.0/8.2 Change Log: 1.0.0 Initial release Click here to download this file Thanks! It is cool. Quote
EvanC Posted January 10, 2011 Report Posted January 10, 2011 Can some one save this in 8.2 so I can take a look at it? If it works for me great, if not I can work around the bug. Thanks Quote
hooovahh Posted January 11, 2011 Report Posted January 11, 2011 Awesome, I don't need this right now but there have been times where something like this would have came in handy. Quote
