Analog to USB to NI IMAQ for USB
Link slightly broken, try DFGUSB2 . I don’t know if IMAQ for USB will work here, only used regulater IMAQ. There is however a Labview "Driver" (see drivers and software tab) for this frame grabber. Don’t know its capabilities or requirements. You could try downloading and see if it looks good. Will likely make it a mute point.
Edited by ESST
Hi ESST,
Thank you for your reply and pointing out the LabVIEW driver. I am also looking at some multi-input analog to usb converters.
As long as the manufacturer provides directshow filters I should be ok to use the NI-IMAQ for USB, right?
