Analog to USB to NI IMAQ for USB
I would like to connect an analog camera to LabView. The analog framegrabbers NI offers are somewhat expensive, and I'm running out of PCI slots.
Would getting a Analog to USB converter (such as http://www.i-cubeinc.com/pdf/frame%20grabbers/TIS-DFGUSB2.pdf) then using NI-IMAQ for USB Cameras make sense?
I have tried to get to the NI-IMAQ for USB site but it seems to be down for the moment.
Thank you!
Link slightly broken, try DFGUSB2 . I don’t know if IMAQ for USB will work here, only used regulater IMAQ. There is however a Labview "Driver" (see drivers and software tab) for this frame grabber. Don’t know its capabilities or requirements. You could try downloading and see if it looks good. Will likely make it a mute point.
Edited by ESST
