levin.hua Posted August 13, 2009 Report Posted August 13, 2009 I installed a R&S CMD60 driver in my PC, and i can use its vi by select add vi, but i am wondering how can i select this vi in control pane directly? Just like we can select DAQ, Motion...... VI. That will decrease little workload to search the path where the driver is. Quote
jgcode Posted August 13, 2009 Report Posted August 13, 2009 (edited) I installed a R&S CMD60 driver in my PC, and i can use its vi by select add vi, but i am wondering how can i select this vi in control pane directly? Just like we can select DAQ, Motion...... VI. That will decrease little workload to search the path where the driver is. Hi Levin {by control pane I am assuming you mean functions palette) If the drivers did not come with a palette file you make your own. I recommended sticking the driver folder under the LabVIEW hierarchy e.g. <user.lib> (or where ever) and create a palette menu for them by selecting Tools>>Advanced>>Edit Palette Set from the LabVIEW menu. Alternatively you could use VIPM. Cheers Edited August 13, 2009 by jgcode Quote
