Clio75 Posted August 20, 2009 Report Share Posted August 20, 2009 I had an idea . That I can have different sequence for different instruments. and from different test I can call a sub sequence. Like -Instrument 1 init Read 1 sett 1 load setting - Instrument 2 init Read 1 sett 1 load setting Test Sequence : Insrument 1 init call init in instrument1.seq Instrument 2 init call init in instrument2.seq read level call read1 in instrument.1seq Read volt Call read2 in instrument2.seq And then if you fix a bug in one of your instrument, you will have this implemented direct in all you sequence. So far all OK. But how to handle the values between the sequence?? I like to avoid using station globals. due to the fact that I need to sett up all station globals on each station. And this makes the deployment part more pain in the ...... So if any have suggestions or other alternatives please share your great idea with me Thanx Quote Link to comment
Aristos Queue Posted August 22, 2009 Report Share Posted August 22, 2009 Can you post an image of a couple of these sequences you're proposing? It would help to see in order to suggest data passing mechanisms. Quote Link to comment
Clio75 Posted August 25, 2009 Author Report Share Posted August 25, 2009 Hello I have attached the project. Testing.zip Quote Link to comment
Sergey Kolbunov Posted August 27, 2009 Report Share Posted August 27, 2009 Hello I have attached the project. Hi Clio, I can not open your sequence because I'm still using TS4.0. What about your question "how to handle the values between the sequence?", I'm using two ways, passing parameters or propagating locals. I suppose what you are using a top level sequence which calls your instrument sequences as sub sequences. Than for the passing parameters method, you need to call each subsequence and pass by reference the variable as parfameter. If the parameter is modified in a first subsequence, the second subsequence will use the modified value. Propagating locals method is even easyer to implemet. You need to define a local in the top level subsequence and check Propagate to Subsequence for this local (right click on the local). Than just use this locals in subsequences, you even don't need to define it there if you are not going to run these subsequences by itself. If you still define the local in subsequences, the Allow Propagation from Caller should be checked. This method works the same way as passing parameter, the modified local is used in later called subsequences. TestStand will highlight the propagated local as invalid, it is valid at runtime. Personally I preffer the propagate locals method, it is less maintanance for subsequences, parameters don't need to be changed for sequence call steps each time when data type is modified. I've attached the examples (TS4.0) Parameter Passing Example.seq Propagate Local Example.seq Quote Link to comment
Clio75 Posted August 27, 2009 Author Report Share Posted August 27, 2009 What about your question "how to handle the values between the sequence?", I'm using two ways, passing parameters or propagating locals. I suppose what you are using a top level sequence which calls your instrument sequences as sub sequences. Than for the passing parameters method, you need to call each subsequence and pass by reference the variable as parfameter. If the parameter is modified in a first subsequence, the second subsequence will use the modified value. Thanx for your examples. The Idea was to call other seq files that is not in the current file. I think the Parameter passing is what I need. In my project I need to pass over the instrument port, so I think this will work. Thanx. I didn't figure out the propagate thing yet. but I will look into it later I have to be finnished with something first Quote Link to comment
Sergey Kolbunov Posted August 28, 2009 Report Share Posted August 28, 2009 Thanx for your examples. The Idea was to call other seq files that is not in the current file. I think the Parameter passing is what I need. In my project I need to pass over the instrument port, so I think this will work. Thanx. I didn't figure out the propagate thing yet. but I will look into it later I have to be finnished with something first Both methods will work with calling other sequence file. It is no difference for TestStand to call a sequence from the same sequence file or a sequence from other sequence file. Oh, no, the difference is what you can not use FileGlobals for different files. But if you don't have a bad habit of using globals, you are ok. Quote Link to comment
Clio75 Posted August 28, 2009 Author Report Share Posted August 28, 2009 Both methods will work with calling other sequence file. It is no difference for TestStand to call a sequence from the same sequence file or a sequence from other sequence file. Oh, no, the difference is what you can not use FileGlobals for different files. But if you don't have a bad habit of using globals, you are ok. In order to get started I have used both file-globals and station-globals. But I hope to change this now. I think I use propagate inside a seq. But parrameter between seq. I think I just do some testing THANX Quote Link to comment
Clio75 Posted September 8, 2009 Author Report Share Posted September 8, 2009 Have you seen any problems with string when propagate them. I have a challenge with the addressing our equipment. it's using ascii base protocol and addressing from 00 to 79. So when I propagate the variable Poss th value change from 07 to 7 and then I missing a char. and this makes the sequence failing (of course). Any I idea ?? Thanx Quote Link to comment
Sergey Kolbunov Posted September 9, 2009 Report Share Posted September 9, 2009 (edited) Have you seen any problems with string when propagate them. I have a challenge with the addressing our equipment. it's using ascii base protocol and addressing from 00 to 79. So when I propagate the variable Poss th value change from 07 to 7 and then I missing a char. and this makes the sequence failing (of course). Any I idea ?? Thanx Do you pass that address as numeric? Try string then. P.S. I just found your description of the problem in the neighbour topic. Sounds mysterious for me, I have no idea, sorry. Edited September 9, 2009 by Sergey Kolbunov Quote Link to comment
