Property loader and Array
Clio75
I'm trying to use the property loader in Teststand 4.1.1 and load and array into an array variable.
But I always have problems, or unloaded value.
So I have tried:
Testarray[tab]test1[tab]test2[tab]test3[tab]test4
OR
TestArray
[tab]test1
[tab]test2
[tab]test3
[tab]test4
OR
Testarray[tab]test1,test2,test3,test4
or XML
TestArray <Prop Name="TestArray" Type="Array" LBound="[0]" HBound="[4]" ElementType="Number">
<Value ID="[0]">CRC</Value>
<Value ID="[1]">ATT-6</Value>
<Value ID="[2]">CRC</Value>
<Value ID="[3]">ATT-13</Value>
</Prop>
If you like to test this, the first 5 in the uut serial number must be 12345 :cool:
Testing.zip
I use the following to represent arrays in files for the property loader:
ArrayName[0]<tab>ElementValue0
ArrayName[1]<tab>ElementValue1
ArrayName[2]<tab>ElementValue2
  • 2 weeks later...
Tested and working :worshippy:
