VI Scripting and EXE files
Jai15
  • 2 months later...
Convert you program into two parts. Application and Scripting engine. Let the application be as exe and this exe will dynamically load scripting engine VI in LabVIEW application Instance using its Port and run the Scripting Engine with Required inputs. This the only way to do if you want to build a scripting based software product.
Rajkumar
Rajkumar
If this is a route consider, then here is a link to a previous discussion with examples.
Cheers
JG
  • 9 years later...
Rajkumar
Hi Rajkumar, Do you have any example code for those things.
Thanks
Edited by Balamurugan K
Greetings
