Dan Bookwalter N8DCJ Posted September 27, 2009 Report Posted September 27, 2009 Ok , it has been awhile since I have had to use the webserver for remote panels , but , i cannot get the server to start up , it is enabled in the apps INI. ther emust be something that i am overlooking ?!?!? I have the settings in the app builder set to copy the LV ini , i have the webserver turned on in the dev environment... what am I missing, i desperately need to get this working Dan Quote
Ton Plomp Posted September 27, 2009 Report Posted September 27, 2009 You probably have two webservers active on the same port (80 the default), try changing the port on either one (development environment or executable). Ton Quote
Dan Bookwalter N8DCJ Posted September 27, 2009 Author Report Posted September 27, 2009 You probably have two webservers active on the same port (80 the default), try changing the port on either one (development environment or executable). Ton I checked that , there isn't anything else running.... Quote
Dan Bookwalter N8DCJ Posted September 27, 2009 Author Report Posted September 27, 2009 Ok , it has been awhile since I have had to use the webserver for remote panels , but , i cannot get the server to start up , it is enabled in the apps INI. ther emust be something that i am overlooking ?!?!? I have the settings in the app builder set to copy the LV ini , i have the webserver turned on in the dev environment... what am I missing, i desperately need to get this working Dan Ok , i figured it out , i had to go into the niwebserver.conf file and change the document root from .//..//...//www to c:/www Dan Quote
