Blackdragon Posted October 3, 2009 Report Share Posted October 3, 2009 For some while I have a Daq-Card 6024E. I'm trieing to generate a digital waveform from the digital IO of the card. I can generate a digital waveform but the timing of the waveform isn't used for timing of the digital output. Thus the signal is processed as fast as posible by the Daq-Card. The problem and my question is how do I control the timing of the digital waveform with the Daq-Card? Quote Link to comment
Neville D Posted October 7, 2009 Report Share Posted October 7, 2009 For some while I have a Daq-Card 6024E. I'm trieing to generate a digital waveform from the digital IO of the card. I can generate a digital waveform but the timing of the waveform isn't used for timing of the digital output. Thus the signal is processed as fast as posible by the Daq-Card. The problem and my question is how do I control the timing of the digital waveform with the Daq-Card? Take a look at the examples under DAQ. Also, posting your VI will get you help a lot faster. Neville. Quote Link to comment
Tim_S Posted October 8, 2009 Report Share Posted October 8, 2009 What amount of determinism do you need in your digital streaming? You're at the mercy of the operating system without hardware clocking. Quote Link to comment
