Choosing a DAQ
Eugene
Hi guys,
Currently i need to produce 4 digital ouput with 3V. The 4 input will be activated from Labview itself.
What kind of DAQ should i buy?
Regards,
Eugene
most digital outputs are 5 V i Believe.
It also depends on how much current you need to supply. A USB-6008 might work for you if you dont need a lot of current.
Otherwise I would go with a USb Compact DAQ chassis (since it is powered), or if you need the 3 V only, you might need to go with a compactdaq relay module and feed 3 V through it.
I once used a NI 6541 and if I recall correctly, the digital outputs were configurable - I looked it up and they can be configured at 1.8, 2.5, 3.3, and 5.0. These are not inexpensive units, however.
Mark
