candidus Posted October 15, 2009 Report Posted October 15, 2009 Hi there, I looked for a way to get the IID from an ActiveX Refnum. So I looked at the TypeDescriptor and fortunately it contains not only the IID but also the CLSID and TypeLibrary of the underlying interface. But I'm still looking for a way to Check whether my Input Variant contains an ActiveX Refnum. I can check for Refnum, but it must be an _ActiveX_ Refnum, else my VI has to return an error. Currently I'm checking the length of the TD but I don't think that's an error-proof solution. Has anyone a better idea? GUIDsFromAxRefnum.viFetching info... Quote
asbo Posted October 15, 2009 Report Posted October 15, 2009 Is there some reason you can't use an Automation reference and Variant To Data? ActiveXVariantToAutomationRefnum.viFetching info... 1 Quote
candidus Posted October 15, 2009 Author Report Posted October 15, 2009 On 10/15/2009 at 1:05 PM, asbo said: Is there some reason you can't use an Automation reference and Variant To Data? ActiveXVariantToAutomationRefnum.viFetching info... Great! I didn't think about that but it's exactly what I was looking for. Thank you very much! Quote
Aitor Solar Posted October 15, 2009 Report Posted October 15, 2009 If you still want to test the variant type before trying the variant casting, the 6th byte in the typedesc will tell you the refnum type (value 7 is for ActiveX Automation references). Though I do agree the other way is probably faster. Saludos, Aitor Quote
candidus Posted October 15, 2009 Author Report Posted October 15, 2009 On 10/15/2009 at 1:55 PM, Aitor Solar said: If you still want to test the variant type before trying the variant casting, the 6th byte in the typedesc will tell you the refnum type (value 7 is for ActiveX Automation references). Though I do agree the other way is probably faster. Saludos, Aitor Thank you! I already noticed that this byte must have something to do with the Refnum type but I was unsure. Is there any documentation about that? The LV documentation tells something about TDs of plain types but not much about Refnum TDs... Quote
ShaunR Posted October 15, 2009 Report Posted October 15, 2009 On 10/15/2009 at 2:36 PM, candidus said: Thank you! I already noticed that this byte must have something to do with the Refnum type but I was unsure. Is there any documentation about that? The LV documentation tells something about TDs of plain types but not much about Refnum TDs... Refnum Data Types Quote
candidus Posted October 15, 2009 Author Report Posted October 15, 2009 I missed this information several times before... Many thanks! Quote
