Ammar Posted October 15, 2009 Report Posted October 15, 2009 Hi all I have problem in this things if any one can help me I have system measure data (i.e pressure )for long time Can I draw 3 wave form one display day value under graph post date as (dd-mm-yyyy) next day draw anew graph And after that we take the mean of each day and put it month waveform under graph post date as (mm-yyyy) and same in year Second if I can do that in table form Last think if I can print front panel automatic at the end of day Thanx for all Quote
Gary Rubin Posted October 16, 2009 Report Posted October 16, 2009 Hi all I have problem in this things if any one can help me I have system measure data (i.e pressure )for long time Can I draw 3 wave form one display day value under graph post date as (dd-mm-yyyy) next day draw anew graph And after that we take the mean of each day and put it month waveform under graph post date as (mm-yyyy) and same in year Second if I can do that in table form Last think if I can print front panel automatic at the end of day Thanx for all This is all possible in LabVIEW. You will get better responses in this forum if you ask more specific questions and show what you have already tried. People here are more than happy to help, but nobody wants to feel like they're doing your coding for you. Quote
ShaunR Posted October 16, 2009 Report Posted October 16, 2009 Yes you can. What do you have so far? If you post your vi, we can see the direction you are taking and advise better. In my opinion, the best way to approach long term graphing is to continuously log the data and provide "views" of that data. To prevent files getting too large (and therfore taking ages to load in the views), you can save the data log in a number of files (either using the date in the filename, or directory name). This would give you a file (or set of files) for each day or month which can be loaded "raw" and processed to provide whatever analysis you require. Quote
Ammar Posted October 19, 2009 Author Report Posted October 19, 2009 hi thanx alot i am work on project and now i am try the example in labview i am stil new can u see plz attachment until now i didn't reach my gole i have one idea for printing report but i do not know if i can do it that comper real time with the loop when the day finsh enable "printing report " but for displaying waveform any one have idea? help me Ammar 1st try .vi Quote
Minh Pham Posted October 21, 2009 Report Posted October 21, 2009 hi thanx alot i am work on project and now i am try the example in labview i am stil new can u see plz attachment until now i didn't reach my gole i have one idea for printing report but i do not know if i can do it that comper real time with the loop when the day finsh enable "printing report " but for displaying waveform any one have idea? help me Ammar pretty shocking 1st try to look at but it is good that you are start looking at some shipping LV's examples. Please go through some of the examples under Help to have some general idea on how to acquire data, sampling rate etc... display waveform of data using graph and xy graph. Finally look at some of the fundamental loop structures to have a better understanding of using a simple architect for ur apps. Hope this helps Quote
Ammar Posted October 23, 2009 Author Report Posted October 23, 2009 pretty shocking 1st try to look at but it is good that you are start looking at some shipping LV's examples. Please go through some of the examples under Help to have some general idea on how to acquire data, sampling rate etc... display waveform of data using graph and xy graph. Finally look at some of the fundamental loop structures to have a better understanding of using a simple architect for ur apps. Hope this helps thanx alot i will try ur advice but i can't achive "comper with real time " in case structures if anyone have example uploaded plz Ammar Quote
ShaunR Posted October 23, 2009 Report Posted October 23, 2009 thanx alot i will try ur advice but i can't achive "comper with real time " in case structures if anyone have example uploaded plz Ammar Ooooh. I'm getting confused between this thread and the axis one Have a look at this A little bit of thought and it can be extended to acheive what you require. Quote
Ammar Posted October 24, 2009 Author Report Posted October 24, 2009 Ooooh. I'm getting confused between this thread and the axis one Have a look at this http://lavag.org/top...__0entry67767 A little bit of thought and it can be extended to acheive what you require. thanx alot but there is one problem i am using labview 8.2 and the attachment saving in 8.5 could u plz reupload in 8.2 version Quote
ShaunR Posted October 25, 2009 Report Posted October 25, 2009 thanx alot but there is one problem i am using labview 8.2 and the attachment saving in 8.5 could u plz reupload in 8.2 version As you probably read on the other thread. I cannot save to a version less than 8.6. I did try to download 8.6 and install it to see if I could do what Asbo did, but it fails to install in Windows 7. Perhaps some kind soul will convert it for you as Asbo did for the other poster. Quote
asbo Posted October 26, 2009 Report Posted October 26, 2009 C:\Documents and Settings\christopher_beuschel\Desktop\Logger Get Axis.vi (Logger Get Axis.vi) The object "Add" does not support output configuration in the previous version. The object "Add" does not support output configuration in the previous version. Opens and has a run arrow in 8.2.1; doesn't look like the warnings are an issue. Logger 8.2.zip 1 Quote
ShaunR Posted October 26, 2009 Report Posted October 26, 2009 Opens and has a run arrow in 8.2.1; doesn't look like the warnings are an issue. Your a sweety Quote
asbo Posted October 26, 2009 Report Posted October 26, 2009 I do it all for the rep-points, yeah, the rep-points, yeah, the rep-points... 2 Quote
Ammar Posted October 27, 2009 Author Report Posted October 27, 2009 thanxxxxxx alot guys i will try to modify it thanx Ammar Quote
ShaunR Posted October 27, 2009 Report Posted October 27, 2009 thanxxxxxx alot guys i will try to modify it thanx Ammar Another tip. If you store the folders/files with the names in a "year-month-day" format (e.g 2008-10-02), then when you browse the folders they will be sorted chronologically. If you do it day-month-year they will be all over the place. 1 Quote
