infinitbelt Posted October 16, 2009 Report Share Posted October 16, 2009 Hi, I am having a bit of a problem getting my program to work properly. As I have it set up right now, I have a while loop as the outer-most structure. Inside the while loop, I have an event structure (on Value Change). Inside the event structure I have a case structure. The different cases in the case structure correspond to the possible value changes that the event structure detects. Is there any way to constantly repeat events in a certain case structure until the event structure detects a different value (a value change)? I tried putting a while loop inside one of the case structures, but the program just waits in the while loop and ignores any input that is supposed to cause the event structure to detect a value change (and thus execute events inside a different case). I also tried having an external boolean wired to the stop button of the while loop inside a certain case but that did not seem to work either. Any ideas are greatly appreciated. Thanks! Link to comment
ShaunR Posted October 16, 2009 Report Share Posted October 16, 2009 (edited) Hi, I am having a bit of a problem getting my program to work properly. As I have it set up right now, I have a while loop as the outer-most structure. Inside the while loop, I have an event structure (on Value Change). Inside the event structure I have a case structure. The different cases in the case structure correspond to the possible value changes that the event structure detects. Is there any way to constantly repeat events in a certain case structure until the event structure detects a different value (a value change)? I tried putting a while loop inside one of the case structures, but the program just waits in the while loop and ignores any input that is supposed to cause the event structure to detect a value change (and thus execute events inside a different case). I also tried having an external boolean wired to the stop button of the while loop inside a certain case but that did not seem to work either. Any ideas are greatly appreciated. Thanks! Well a Value Change(signl) property node will programmatically fire an event but you can end up with race conditions. You ought to be wiring a timeout to the event case (say 100ms the, default is -1....wait indefinately) and checking the controls in the timeout case. If you are seeing the event execute only once, then it is likely that you do not have the control inside that event case. This is required for the control to be "reset". Edited October 16, 2009 by ShaunR Link to comment
Mark Yedinak Posted October 16, 2009 Report Share Posted October 16, 2009 It sounds like your application could benefit from using a producer consumer architecture. Use a single event structure in one while loop that will detect the value change and have the event notify the consumer of the new value. A state machine in the consumer could process the data as required and if necessary repeat over the action until a new value is detected. Link to comment
ShaunR Posted October 16, 2009 Report Share Posted October 16, 2009 It sounds like your application could benefit from using a producer consumer architecture. Use a single event structure in one while loop that will detect the value change and have the event notify the consumer of the new value. A state machine in the consumer could process the data as required and if necessary repeat over the action until a new value is detected. A bit excessive dont ya think? Link to comment
smenjoulet Posted October 16, 2009 Report Share Posted October 16, 2009 A bit excessive dont ya think? Why would you say that? I think Mark's proposal is valid, as is yours. When I first read the question, the first thoughts that came to my mind were both of your solutions. Ultimately, it is a design decision for the developer to make and he doesn't offer up enough additional information to make a choice. -Scott Link to comment
ShaunR Posted October 16, 2009 Report Share Posted October 16, 2009 Why would you say that? I think Mark's proposal is valid, as is yours. When I first read the question, the first thoughts that came to my mind were both of your solutions. Ultimately, it is a design decision for the developer to make and he doesn't offer up enough additional information to make a choice. -Scott My reply wasn't a design proposal. It was to get his events working properly. Like you said. theres not a lot of detail, but its likely its a control with a couple of cases checking a value. Do you really need a Consumer-Producer design pattern with state machines to see if a value is higher or lower than zero for example? Link to comment
smenjoulet Posted October 16, 2009 Report Share Posted October 16, 2009 Do you really need a Consumer-Producer design pattern with state machines to see if a value is higher or lower than zero for example? No, probably not, in which case yours is the simpler solution. I would agree based on the question that is the more likely scenario. But it could also possibly be that he is monitoring multiple controls for value change in the same event case, which starts to favor a producer-consumer or some similar design. And it's a personal preference of mine that I try to avoid using timeouts in the event structure unless really necessary. There are times when it makes sense, and it's still superior to polling. But it still *feels* like I'm resorting to polling before we got the event structure. Man, doesn't that seem like ages ago. Link to comment
ShaunR Posted October 16, 2009 Report Share Posted October 16, 2009 No, probably not, in which case yours is the simpler solution. I would agree based on the question that is the more likely scenario. But it could also possibly be that he is monitoring multiple controls for value change in the same event case, which starts to favor a producer-consumer or some similar design. Well. If that is the case then there should be an event case for each control or set of dependent controls. Still don't see the need to complicate it further. And it's a personal preference of mine that I try to avoid using timeouts in the event structure unless really necessary. There are times when it makes sense, and it's still superior to polling. But it still *feels* like I'm resorting to polling before we got the event structure. Man, doesn't that seem like ages ago. Me too. and re-reading what I posted I did say they should be checked there. What I was really getting at was to add a timeout so that his vi doesn't "hang". I think once he posts more, we will probably see that his issue is understanding how and why an event structure works the way it does rather than a design implementation. After all there are a few unintuitive things like having the control inside the event case. Link to comment
Mark Yedinak Posted October 16, 2009 Report Share Posted October 16, 2009 A bit excessive dont ya think? It depends on his application as both you and Scott discussed. The thought that came to mind though when I read the original post was that he was trying to do polling using an event structure. Like Scott, I try to avoid using the timeout event in an event structure. I also prefer to use events rather than polling. As for a producer consumer architecture being excessive I don't really think it is. At least not for anything that will be an application and interact with a user. It isn't that challenging of an architecture to understand and it provides lots of flexibility and extensibility for an application. It is the architecture of first choice for any application I write. No I'm saying that it is the greatest thing since sliced bread but it is a proven architecture for applications where user interaction will be involved. Link to comment
ShaunR Posted October 17, 2009 Report Share Posted October 17, 2009 Poor OP. He posts an innocent question and all he really gets is a load of old women arguing about thier crochet patterns 1 Link to comment
crelf Posted October 17, 2009 Report Share Posted October 17, 2009 He posts an innocent question and all he really gets is a load of old women arguing about thier crochet patterns hey Hey HEY! I said drop 2 curl 3, not drop 3 curl 2! 1 Link to comment
smenjoulet Posted October 18, 2009 Report Share Posted October 18, 2009 Poor OP. He posts an innocent question and all he really gets is a load of old women arguing about thier crochet patterns hey Hey HEY! I said drop 2 curl 3, not drop 3 curl 2! HEY! I resemble that! I'll argue most anything for fun. But I'm glad you said it and not me. I wonder... Did he ever get his program working the way he wants or did we just send him into an infinit loop? Link to comment
Cat Posted October 22, 2009 Report Share Posted October 22, 2009 He posts an innocent question and all he really gets is a load of old women arguing about thier crochet patterns Old women? What are you implying, Shaun? Link to comment
ShaunR Posted October 22, 2009 Report Share Posted October 22, 2009 Old women? What are you implying, Shaun? Link to comment
Cat Posted October 25, 2009 Report Share Posted October 25, 2009 Hey, sonny, you better show some manners. I've got a big purse. Link to comment
Please sign in to comment
Sign In Now
