ooth Posted November 3, 2009 Report Posted November 3, 2009 I'm not sure if this is a LV2009 thing or not but I cannot get the context help to show the VI description when the VI is part of a polymorphic group. If I open the VI and then put the cursor over the icon then the help text appears but not when its on another VI's BD or in the palette. This happens with some of the OpenG VIs and others actually show the description text. I must be missing something. Thanks Quote
Aristos Queue Posted November 3, 2009 Report Posted November 3, 2009 A VI has no idea that it is a member of a poly VI (indeed, the same VI can be a member of many polyVIs). The only time you'll see poly VI help is when you're over the poly VI itself. Quote
crelf Posted November 3, 2009 Report Posted November 3, 2009 ...the same VI can be a member of many polyVIs... Intriuging. I must admit that I've never even tried to do that. Now I'm going to have to have a good think on why I would... Quote
Aristos Queue Posted November 4, 2009 Report Posted November 4, 2009 Intriuging. I must admit that I've never even tried to do that. Now I'm going to have to have a good think on why I would... There's only one case I know of... there's a set of VIs... all of them work on the desktop but only a subset of them work in real-time environment. So there are two different poly VIs, one in the desktop palettes, one in the RT palettes. Quote
