jgcode Posted November 13, 2009 Report Posted November 13, 2009 This Quick Drop Plugin will rename the owning Data Member VI's LVOOP Front Panel Objects' Labels to <class name> In for the control and <class name> Out for the indicator (which is similar to what the defaults are now in LV2009). This was one of the first things I did after the Quick Drop Plugin was released and I use it all the time, so I thought others may use it. I use it when I change the name of a Class or when I clone a VI manually. Instructions: On a Data Member VI press [Ctrl + Space] to bring up the QD Dialog then press [Ctrl + Z]. If you press [Ctrl + Shift + Z] it will update the all Data Member VIs in that Class. I use Shift when I Save As... a Class so I don't have to do each one. I would be interested to know if it can be optimised. It is fast when the Class Library is only open but in a Project it is quite slow when it does the entire Class. Also the Undo Stack is supported however, when you rename across a Class (multiple VIs) it only works for the VI you QD on. Anyone know a work around? icon_qdp_rename_lvoop_labels-1.0-1.ogp [LabVIEW2009] Quote
jgcode Posted November 29, 2009 Author Report Posted November 29, 2009 This code has been updated and added to the LAVA-CR. It can be downloaded here. Cheers JG Quote
