Library
Germi
Hi everyboby,
i have a problem with the Mathlibrary:reflection point.vi because i change the block diagram and i saved the modify, but now i need to come back and i do not remember how was. Someone can help me, and tell me where i can find it?
Thanks
Hi everyboby,
Thanks
If you do a repair of LabVIEW it will reinstall all the vi.lib VIs.
Another possibility is to search inside the CAB files on your installer DVD's, the file should be inside it. I think there is a special vi.lib distribution item on the DVD with only the vi.lib elements.
Ton
Hi everyboby,
Thanks
Hi Germi
It not a good idea to change vi.lib VIs and leave them in the same location. Anyways, I did a search for Reflection Point.vi in LabVIEW 2009 and all that got returned was an MGI VI named Bezier Reflection Point.vi.
Are you sure the name is correct?
Cheers
JG
