Christian Kjeld Posted March 3, 2004 Report Share Posted March 3, 2004 I am using LabVIEW 7.0 and I have a problem with how to dial up on a VPN connection. In Windows 2000 you can make several dial-up connections that I manually can connect to. These connections have a username/password and are using a modem to connect to the site server. I would like to control these dial-up connections, either directly or indirectly from my data server program, programmed in LabVIEW 7.0. Is there someone who has any experience in have to do this? Link to comment
Michael Aivaliotis Posted March 4, 2004 Report Share Posted March 4, 2004 I don't have Windows 2000 anymore but I believe that the dial-up connections reference specific configuration files. It's possible, I suspect, to call those configuration files through the LV system exec and in-turn they would make the connection. However if a specific file is not available then prehaps you can create a short-cut for the specific connection then call the short-cut. Probably a better method would be to access the Remote Access Services (RAS) directly through a Windows API call. Go onto the Microsoft MSDN site and see what you can find. You need to call the C:\WINDOWS\system32\rasapi32.dll. The function you need is RasDial: The RasDial function Some more research reveals a toolkit that will do RAS dialing in LabVIEW: RAS-Toolkit LV Link to comment
Christian Kjeld Posted March 4, 2004 Author Report Share Posted March 4, 2004 Hi Michael Thanks for your help, now I am on track again. Best regards Christian Kjeld Link to comment
Mario Posted March 4, 2004 Report Share Posted March 4, 2004 Hello Christian I've done some work with RAS dial up connections and LabView. The easiest way is to use the command line. First you have to create a new RAS item. Then you can initiate a RAS connection with "rasdial 'RAS connection name' 'name@password'", close "rasdial "connectio name" /disconnect. To check for the connection status i've used the TCP/IP Funktions in LabVIEW (Error Messages). Or maybe you would use this libs. http://www.lauwers.com/lv.htm i've found. Greetings Mario Link to comment
Please sign in to comment
Sign In Now
