Make Window Tranparent
Cool. We can now do arbitrarily-shaped splash screens that fade into view over a second or so. I've been meaning to do that ever since I got .NET but never had the time/motivation/justification.
And I have a big oval with the word "BOO!" in it that occasionally fades in at a random place on the screen and then fades out again.
So is there a real use you had for this? :)
post-10-1079384349.jpg?width=400
Well, I was thinking to use it to overlay my image window to other windows so that user can draw on the image window, but at the same time see the underneath window, for the purpose of some instruction or training software, an idea is if you can overlay on top of your graph and make some marks (circle, rectangle or line) like a professor. I thought other people may be interested in it too, so I donate here. :)
Neat. Surely someone's already done this for IT training? I'd have thought someone with a laptop and projector teaching a class would already have been doing this but I've never looked.
Might also be an easy way of overlaying static or animated illustrations on video footage; Powerpoint NextGen.
We did a project once where we were just scripting video and monitoring the reactions of the viewers. The psychology researchers who contracted us had edited the videos to obscure, for example, the eyes, to observe the effect of reduced information. That would have been a much better system with this to allow them to modify the footage on the fly.
Yes, you are right, the white area would become transparent forever. That is because some bit set of the window need to reset back. I need to finish up the things on my hand before I can take a look into it. I'll keep you folks updated. Sorry for the meanwhile just restart your LabVIEW everytime. I know it's not very nice though, but... ;)
Hello
I just want to mention that there is an other possibility to make windows transparent.
If you only need the feature in WINDOWS OS environment than use the API from WINDOWS itself !
I'm currently working on an OpenG addon for doing such kind of stuff.
If you would like to test my Example VI please put the content of "lvwutil32.zip" in the user.lib folder.
with best regards
Mario
Download File:post-19-1079538066.rar
Well, Irene's post IS using the standard Win API.
I can't get yours to work. It's correctly getting a win refnum but the return from getWindowLong is zero, which I guess is not right.
You're using a sequence unnecessarily; frame 1 is dependent on frame 0 and the code can be in the same frame because dataflow will ensure it works in the right sequence. It may not matter which order the second two function calls take place in either. Sequences with sequence locals and wires backtracking across each other is a pain, IMHO.
I wasn't- I was using "Transparency.vi Front Panel".
But it doesn't appear to work using "Transparency.vi" either, yet again Get Window Refnum is returning a refnum and GetWindowLong is returning zero.
If I deliberately type garbage then Get Window Refnum returns zero, so it seems it IS correctly getting the window at the start.
Curious.
Hello
You have to leave out the "Front Panel" substring and only use "Transparency.vi" cause LabVIEW adds the string "Front Panel" to the String in the Window, but the name is only "Transparency.vi"
Hope it helped.
have a nice day
Mario :D
Yes- I have tried "Transparency.vi" two posts back and it don't work.
Anyone else tried it here and care to comment?
I'm on XP. What OS was it developed on? Though any major changes would have brought up errors that the function wasn't found in the DLL.
Hello!
I tested the VI called Transparency.vi and it runs...
To test this vi I copied several files to my /LabVIEW7/user.lib folder
LVWUtil32.dll 33kb
MANUAL.WRI 468kb
Readme.doc 24kb
Winevent.llb 541kb
WINKEY.LLB 68kb
WINNET.LLB 51kb
Winsys.llb 164kb
WINUTIL.LLB 646kb
My system: WinXP SP1, LabVIEW7
I testet the VI with different windows, like notepad and so on... and it works...
  • 3 weeks later...
  • 3 months later...
For me this seems like the transparency after running the vi is actually a redraw-problem.
If you move the help window on top of a white window, background will change back from transparent to white again.
At least for me it does, is the behaviour the same with other users as well?
Furthermore I couldn't download Irene's source code and don't actually know how this is done, thus I'm not able to debug it further. :blink:
Nice thingy, might use it sometime just for fun if I can reverse the transparency programmatically.
