JasonXCX Posted January 22, 2010 Report Posted January 22, 2010 Mapple and Simulink are interesting but too expensive for most of my students. What do you think of Maxima and Octave ??? Quote
vugie Posted January 22, 2010 Report Posted January 22, 2010 I've used Maxima for few times to perform some sybolic calculations (mainly differenciation of matrix equations) and it went quite smootly. I didn't use Mapple, so I can't compare them. Not so long ago I used Scilab a lot. It's open source Matlab-like environment with Scicos component which is Simulink equivalent. Syntax is really similar to Matlab, there are even some tools to convert programs between them. Very stable and mature environment, a lot of free toolboxes, very good and easy visualization and interface building (tk based). Scicos was also good, but its interface was quite not comfortable. I monitor this project periodically and I see that a lot changed since I used it last time and now it seems to be even better. But now I use LV for everthing... Quote
JasonXCX Posted January 23, 2010 Author Report Posted January 23, 2010 On 1/22/2010 at 8:56 AM, vugie said: I've used Maxima for few times to perform some sybolic calculations (mainly differenciation of matrix equations) and it went quite smootly. I didn't use Mapple, so I can't compare them. Not so long ago I used Scilab a lot. It's open source Matlab-like environment with Scicos component which is Simulink equivalent. Syntax is really similar to Matlab, there are even some tools to convert programs between them. Very stable and mature environment, a lot of free toolboxes, very good and easy visualization and interface building (tk based). Scicos was also good, but its interface was quite not comfortable. I monitor this project periodically and I see that a lot changed since I used it last time and now it seems to be even better. But now I use LV for everthing... thank you I will have a try with Scilab and Maxima Quote
