TG Posted February 26, 2010 Report Share Posted February 26, 2010 Hi Guys, I do not have this utility, unfortunately! But Im sure it can be found or made here! From the perspective of a single developer making changes to hiw own code without (the luxury of) source code control it would nevertheless be nice to have a tool allowing a hotkey to quickly insert timestamp string into windows clipboard, all ready to be pasted into a block diagram comment. Does LabVIEW already has this capability? Any API facade VI out there allow to write to the windows clipboard programatically? Example during development, F12 key when pressed would place a nicely formatted time stamp string into the windows clipboard all ready to be pasted on to the block diagram. That would be a great little tool! LV 8.5.1 LV 8.61 LV 2009 Quote Link to comment
crelf Posted February 26, 2010 Report Share Posted February 26, 2010 I do not have this utility, unfortunately! But Im sure it can be found or made here! I'm sure you'd be able to make something really easily with JKI's RCF. From the perspective of a single developer making changes to hiw own code without (the luxury of) source code control... SCC isn't a luxury - it's a necessity, and easy to implement. Quote Link to comment
jcarmody Posted February 27, 2010 Report Share Posted February 27, 2010 Seeing that you have LV2009, you can create your own Quick Drop keyboard shortcut. I don't have 2009 right now, nor have I ever done this, but I expect it'd be easy to accomplish. Here's a blog post with details. The VI would be very simple. As crelf said, a JKI RCF plug-in would be easy, but that's not a hot-key. Quote Link to comment
Phillip Brooks Posted March 1, 2010 Report Share Posted March 1, 2010 Don't forget that there is already a method to add comments to a VI that include a timestamp; its called 'Revision History'. Simply press 'Ctrl-y'. There is a whole category in the LabVIEW options to customize the behavior of this feature. I seem to recall that there was a question on the NI forums at one point about doing away with this function, but I don't recall ever hearing that Rev History would be indeed removed. Found it: http://forums.ni.com/ni/board/message?board.id=features&thread.id=112 Quote Link to comment
Karissap Posted March 2, 2010 Report Share Posted March 2, 2010 Here is an implementation using F12 as a hot key. The input data VIs are used instead of the key down event in the event structure when using hot keys in programs designed to run in the background so the key will be captured even when the program is minimized or hidden. The event method only works when the key is pressed when the front panel is active. copy date time to clipboard.vi 1 Quote Link to comment
TG Posted March 3, 2010 Author Report Share Posted March 3, 2010 Thanks for all the great responses. Always educational. Karissap your solution is totally elegant, Thanks! I had no trouble saving it down to 8.5.1. too for u Quote Link to comment
