Elktro Posted March 4, 2010 Report Posted March 4, 2010 I am currently programming with SciWare's GOOP developer with LabVIEW 7.1. I have a public readwrite method, let's say ClassA.GetValue(). How can I find out whether this method is reentrant or not? thanks, Quote
Yair Posted March 5, 2010 Report Posted March 5, 2010 Why don't you just open the VI and have a look in its properties dialog? Also, note that since it includes a write, it probably only matters if it's reentrant if you're working on two different objects at the same time, as presumably the framework will lock the cluster if you're working on a single instance. 1 Quote
Elktro Posted March 5, 2010 Author Report Posted March 5, 2010 Yeah of course! Found it at Vi Properties -> execution. thanks Quote
Phillip Brooks Posted March 5, 2010 Report Posted March 5, 2010 Yeah of course! Found it at Vi Properties -> execution. thanks Here is a LabVIEW 7.0 VI that you can use to programmatically determine the VI execution state settings for a specific VI. VI Exec Options.vi (LV 7.0) 1 Quote
