simple question about diode
GSR
I learned this topic years ago, and I want someone to confirm my understanding :rolleyes:
Assume I have 2 diodes. The reverse breakdown (BD) voltages are 10V and 6V respectively. They are connected in series.
----------- (-8V+)---------
I think if the 10V BD-diode is on the right and the 6V BD-diode is on the left, both of them will still be OK
If they switch the position, the 6V BD-diode will breakdown
Am I right???? :blink:
I learned this topic years ago, and I want someone to confirm my understanding rolleyes.gif
NO, the circuit will not breakdown under 16V regardless. Since the diodes are in series, if a breakdown were to occur, both diode must break down. Think about this way, when Diode A breakdown, that means a high current would pass through Diode A. If Diode B is connected in series with Diode A and a high current is going through on Diode A, the same current must go through for Diode B as well. If high current has to go through Diode B, that means Diode B must breakdown as well.
Yik
The circuit you are describing would look like this ...
Then, one diode may break down before the other.
The order of the diodes should have no influence whatsover, assuming no other environmental influences (PCB leakage currents, dirt, etc) would influence them in one way or the other.
