Path of calling VI?
  On 3/16/2010 at 12:22 AM, Snelephant said:
A.vi calls B.vi. Is there a way to acquire the path to A.vi from within B.vi without explicitly supplying this to B.vi?
Attached is a zip, in that zip is two VIs A and B. A calls B, and B gets the path of A using a reference to the VI and using a property node.
A Calls B Path.zipFetching info...
Perfect! The key here is the 'Call Chain' function, which I had not been aware of.
Thanks a lot.
Snelephant
