Bryan Posted May 13, 2004 Report Posted May 13, 2004 I know that Test Stand supports Tcl scripts, but I have a need for using the capabilities of Tcl with LabVIEW. For example, for a test system I am currently working on, I would like to control the entire application with LabVIEW, use Tcl for script-driven control and monitoring of NI PXI DAQ. It would be nice to have a Tcl Interpreter library for LabVIEW, just like how there is a MatLAB, Hi-Q and even the formula node. Quote
Albert-Jan Brouwer Posted May 17, 2004 Report Posted May 17, 2004 There is LuaVIEW (http://www.citengineering.com/LuaVIEW/index.html) if you need a scripting language (Lua) but do not need TCL in particular. Note that when tying a scripting language to LabVIEW, a diagram node containing code is the last thing you'd want to use for specifying scripts: such code cannot be changed once your application is running. That defeats half the point of using an interpreter or a compiler/VM pair (the other half being control over execution). Quote
Bryan Posted May 17, 2004 Author Report Posted May 17, 2004 Thank you for posting that link. That looks like it might be just what I'm looking for. I'm going to read up on it to make sure. Thanks! Quote
Mike Ashe Posted June 14, 2005 Report Posted June 14, 2005 I was involved in a telescope control project that used Tcl heavily. Mostly we just used Call Library nodes and passed the items back and forth between Tcl/Tk and LabVIEW. It was reasonably fast and very reliable after the kinks were worked out. Quote
spiritvarun Posted November 1, 2012 Report Posted November 1, 2012 I was involved in a telescope control project that used Tcl heavily. Mostly we just used Call Library nodes and passed the items back and forth between Tcl/Tk and LabVIEW. It was reasonably fast and very reliable after the kinks were worked out. Hi Mike, Can you describe how did you do it , like how on using call function node to pass data back & forth between tcl and LV. I am currently stuck here. I would appreciate your help and if you could give a small ex , will be nice, Thanks, Varun Quote
