Create Shared Variable from VI
Hi all,
the document at http://zone.ni.com/devzone/cda/tut/p/id/4679 in the section titled Programmatic Access says:
"As discussed above, you can create, configure, and deploy shared variables interactively using the LabVIEW Project, and you can read from and write to shared variables using the shared variable node on the block diagram or through front panel data binding. New in 2009, LabVIEW also provides programmatic access to all of this functionality.
Use VI Server to create project libraries and shared variables programmatically in applications where you need to create large numbers of shared variables."
I'm mostly interested in the last part, that is, creating Libraries and shared variables from the VI programmaticly, but I was unable to find the right components to achieve that (I'll keep trying, though). Can someone guide through the process or point me to a VI that does that?
Thanks in advance, Miha
Go to the LabVIEW Example Finder and search for 'shared'. The "Create Online Process.vi" example seemed like the most basic to get started, and then there was a more advanced one.
Thanks, I also did that. Am I correct in assuming this only works if you have DSC Module installed?
Miha
Miha
Yes, the DSC allows programmatic access to shared variables, creating SV etc...
LabVIEW 2009 has a Shared Variable API but it is no where near as powerful as the DSC nor can it do what you are asking.
  • 1 month later...
You can see this post: XDSC
It seems a powerfull toolkit, but I don't have additional information
