vugie Posted April 7, 2010 Report Posted April 7, 2010 Hi I have laaaarge binary file (array of clusters). Not possible to load at once. Read from binary file generates an error (error code 2) and message box "Not enough memory to complete operation" pops up. Ok, I want to load as much as possible (with reasonable margin) - so how to determine what is the largest array I may allocate (at the moment, not generally). What I already tried: Memory manager functions to determine free memory (AZFreemem, AZMemStats) - always return 0 (I found that they are Mac specific functions) Trying to allocate big memory block with memory manager decreasing its size each time when it was unsuccessful (and freeing it again on success) - the size of largest allocatable memory block acquired that way was always much larger than array I was able to initialize (attempt to initialize to large array causes pop up message, but no any programmatic feedback) Sequentially decreasing the array size provided to "Read from Binary File" and parsing error cluster - pops up message each trial (unavoidable) and sometimes does not generate any error, but array loaded is empty So what is best method to programatically determine largest possible array? LabVIEW 8.2 Quote
Cat Posted April 7, 2010 Report Posted April 7, 2010 Welcome to my world... I love LabVIEW dearly and will defend it as a great all-around programming language, except in one area -- memory management. And that's a killer for those of us who have to manipulate/display large data files. My (rather vague) understanding of the problem is that LV generally wants to grab *contiguous* memory. So while you may have plenty of free memory, if it's broken up, LV can't necessarily use it. (I'm sure if I'm wrong someone more knowledgable will jump in here...) My workaround for this is to read the available physical memory, subtract off about 750MB for what I label "LV inefficiencies" and divide the remainder by a "memory loss" value. Trial and error with this has left me with a value of 4 for memory loss. (Available memory - program usage) / memory loss = #bytes of hopefully contiguous memory out there somewhere This is a cludge and isn't really determining what I need to know (available contiguous memory) and I hate it. But it works, most of the time. If anyone else has a better way to do this, I would love to hear it. Quote
vugie Posted April 7, 2010 Author Report Posted April 7, 2010 I suspected sth like this... (Available memory - program usage) / memory loss = #bytes of hopefully contiguous memory out there somewhere And how do you read "available memory" and "program usage"? Quote
Cat Posted April 7, 2010 Report Posted April 7, 2010 And how do you read "available memory" and "program usage"? Program usage I get from eyeballing how much memory just running the program takes up in Task Manager. Then I throw in a couple hundred MB because LV has a bad habit of grabbing memory and not letting it go (even if you use the "anxious deallocation" function). This all should be a fairly constant value, depending on your program. For my program that's about 750MB. Like I said, this is Bad Programming and not how I would like to be doing it if there's a better solution out there. I have a set of Windows API llbs that I've had so long that I don't remember where they came from. Available Physical Memory is in winsys.llb\System Information.vi Windows API.zip Quote
mje Posted April 7, 2010 Report Posted April 7, 2010 My (rather vague) understanding of the problem is that LV generally wants to grab *contiguous* memory. So while you may have plenty of free memory, if it's broken up, LV can't necessarily use it. (I'm sure if I'm wrong someone more knowledgable will jump in here...) Cat is correct. Arrays require continuous blocks of memory. Other languages have things called lists that allow you to load large sets of data in non-continuous memory, but LabVIEW has no such construct built natively into the language. These lists however are not arrays, and do not allow efficient random access to your data. Do you need to load large amounts at once? Standard practice is to read the file in tiny chunks and iterate through the file while running whatever state calculations you need. Or do you need more random access to the data? In that case properly defining your data structure can allow random access to any element on disk with a little bit of math, or alternatively you might be able to "map" your file out ahead of time to allow random access to variable length data. Quote
