Elktro Posted April 20, 2010 Report Posted April 20, 2010 I am customizing a push button control. I added a regular push button control on the front panel and navigated through advanced > customize. I wanted to delete the shadow background of the push button, but wasn't able to delete any of the picture items. As a work a round I resized the shadow pictures to small sizes and made them transparent. But how on earth do I remove them completely? Quote
asbo Posted April 20, 2010 Report Posted April 20, 2010 Just messed with it and ended up with the same solution you had. For whatever reason, I don't think you -can- delete them. Quote
Rolf Kalbermatter Posted April 21, 2010 Report Posted April 21, 2010 Just messed with it and ended up with the same solution you had. For whatever reason, I don't think you -can- delete them. Yes you can't delete sub parts from a control nor adding any. The actual internal structure of a control is very static and specific to each control class. Quote
Grampa_of_Oliva_n_Eden Posted April 21, 2010 Report Posted April 21, 2010 I am customizing a push button control. I added a regular push button control on the front panel and navigated through advanced > customize. I wanted to delete the shadow background of the push button, but wasn't able to delete any of the picture items. As a work a round I resized the shadow pictures to small sizes and made them transparent. But how on earth do I remove them completely? Same issue if you start with a control from the classic palette? Ben Quote
Elktro Posted April 27, 2010 Author Report Posted April 27, 2010 Same issue if you start with a control from the classic palette? Ben Well, classic buttons don't have shadows, but they are ugly! Anyway, you can't delete picture items of classic buttons either. Quote
