Concatinate two PDF files or XLS files
I did this a while ago to merge PDF files using pdftk in LabVIEW.  Put the path to the directory containing your PDF files into the Path Control, add a filter (*.pdf is good) and a name for the new file.  Run the VI, select the pages from each PDF file to go into the new file, press "Go" and Bob will be your father's brother.
LV-pdftk.zip
