Is QSM my best option?
I've got to communicate dynamically with several stations which carry out essentially the same operations, where the parameters are individually input by UI and operation by semaphore-controlled tool function.
Right now I've got the project set up as a QSM as seen in the attached photo.
The top level VI initializes itself, the subVIs and then is idle while the subVIs operate unless an error or stop command is passed. I find myself saving each subVI as a unique file in order to maintain operation of the state machine for each, rather than what seems logical - to place a single reentrant VI. This brings to light my question - is there a better option than a QSM?
You can make a FGV a reentrant VI, but because it contains persistent data (USRs) you use the preallocated option for reentrancy. Therefore, every instance placed on the block diagram will have a unique state.
That may help.
In my opinion, yes! It would change your approach a bit, but if you were willing to use Object-Oriented design patterns you could use a combination of the Command Pattern (in particular, you could include the target controller as an object inside the command, thus handling all commands for all controllers through a single--preferably asynchronous--message channel) and the State Pattern. You can create a Controller class and then create subclasses that inherit from this.
Ah, and there's the rub. I'm just now getting into LabVIEW OOP, and my skills aren't quite up to this level of a challenge. Maybe in a future rev. Thanks.
Check this out
http://forums.ni.com/ni/board/message?board.id=170&message.id=390557
I have used this architecture in some of my projects. I like this when I need to send message to dynamically running VI's
I think I'm going to start calling you Commander Paul. Maybe I'll sponser an over-under line on how many posts you can go without mentioning the command pattern. wink.giflaugh.gif
(I jest. Your advice, as always, is always spot on!)
There's always a better option than a QSM.
(Not that I have an opinion about it or anything...)
Check this out
http://forums.ni.com...ssage.id=390557
I love this idea. This would fit very nicely as a replacement to my current architecture and I can see where it would solve some code issues I have patched with duct tape and good intentions.
