lovemachinez Posted May 14, 2010 Report Posted May 14, 2010 Hi, I have an 2d array(100x100) of temperature values and I want to use it for making the thermal image like I have shown. By the way, I don't know which tool in LV can draw the image like this. How? Best Regards, Quote
McKman Posted May 14, 2010 Report Posted May 14, 2010 Take a look at the example at "LabVIEW XX\examples\math\visualiz.llb\Common Intensity Maps.vi". Mark Quote
rpursley Posted May 14, 2010 Report Posted May 14, 2010 Attached is a vi (LV 2009) that contains a Intensity Graph and the code needed to generate a close approximation to the desired color scheme. Just feed your data into the Intensity Graph and it hopefully will look like you want it. Colors components in the plot are ordered RGB. Thermal Imaging Color Table.viFetching info... Quote
lovemachinez Posted May 18, 2010 Author Report Posted May 18, 2010 (edited) hi, rpursley Do you have LV8.5 Version for your example? I cannot open it. Best Regards Edited May 18, 2010 by lovemachinez Quote
rpursley Posted May 20, 2010 Report Posted May 20, 2010 On 5/18/2010 at 12:46 AM, lovemachinez said: hi, rpursley Do you have LV8.5 Version for your example? I cannot open it. Best Regards Here it is. Sorry it took so long to respond. Thermal Imaging Color Table.viFetching info... Quote
