lovemachinez Posted May 18, 2010 Report Posted May 18, 2010 Hi, all Now,I'm using an image control tool, which come with ni vision development. When I import an image to the control, the image is oversize from the control. How to strech the image, to make it fit to the control. Best Regards, lovemachinez Quote
Ton Plomp Posted May 18, 2010 Report Posted May 18, 2010 You have two options: Make the control bigger Scale the image Here are the two possibilities: Ton Quote
lovemachinez Posted May 18, 2010 Author Report Posted May 18, 2010 Thanks, Ton. I will try your recommended. Well, the method is a little bit complicate. I think I have ever do with easier way, but I forgot already. Does anyone can do this? Please help. Best Regards, lovemachinez Quote
Rolf Kalbermatter Posted May 20, 2010 Report Posted May 20, 2010 Thanks, Ton. I will try your recommended. Well, the method is a little bit complicate. I think I have ever do with easier way, but I forgot already. Does anyone can do this? Please help. Best Regards, lovemachinez Complicated to use the ZoomFactor property??????? All the heavy weight lifting is internally done by LabVIEW for you and you feel it is complicated! 2 Quote
