strange error in Application generating
i meet a strange error in generating exe files with a programme which runs well with source code.i search on net only to find nobody else have met this problem ever before.
the discription of problem :
Possible reasons:
An error occurred while saving the following file:
D:\Sumsang\LV Source\Supports\Camera DLL\Public\LoadImageAsPicture__cam.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
Detail:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1502 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Cannot save a bad VI without its block diagram.
Edited by deadking01
Hello,
Your issue might be similar to the one exposed in this discussion.
First thing to try is to close LabVIEW, re-open and see if it works. If it doesn't you can try to temporarily remove parts of your code to find out which VI causes this problem.
Have you been able to build an exe from this source code earlier or is it the first time you try to build?
